Wheel Allignment after H&R Lowering
909FX
Premium Member
Premium
FONTANA, CA
2010 Honda Crosstour
Ok, so you all know I got my FX lowered. So now I need to get an allignment.
Is $75.00 a good price? STW in La Habra said they will do it for $75.00. I also told them I'm lowered on 22's and they said that was the price.
Need some feed back.
Thanks in advance.
You know, I haven't done an alignment now almost 3 weeks after lowering.... Frankly, I haven't noticed an alignment problem, though something is no doubt tweaked a little. Is it really necessary to perform an alignment?
really except for a slight toe tweek the front doesn't get affected all that much with the drop, the rear does a bit though... you probably wouldn't notice much until you start to see uneven tire wear...
okay, I have a question that may or may not be related to the topics... and I apologize for this is like basic autoshop 101 question... anyway... when I'm driving straight... the steering wheel is a bit off center... is that an alignment issue or tire pressure issue?
I have yet to do an alignment after being lowered 2 years on eibach's. I have not noticed any uneven tire wear or any significant off center veering of the vehicle. Only think I have noticed is is slight negative camber in the rear.
But I will most likely do a alignment next year when I have my tires replace.
could be either, but if it's tracking straight & the wheel is off center it's probably an alignment issue. the first thing that's done in any alignment is to center the wheel & then do all compensation from that point....
Yes, you should get it done since work was done on your suspension. You know, just to be on the safe side. I don't see a difference, but you never know. I got mine lowered about 3 weeks ago also. Think my springs settled nicely now.
Ken, if I were you I would make sure the tire preasure is correct. If your tire presure is fine and your steering wheel is not straight, then I would go get an allignment. Maybe you hit a pot hole or something?
Nope. I was supposed to go back to LMS for the alignment after a month but never got around to it and my FX drives straight so I never bothered to get it done.
so does mine. I thought my steering wheel was going to be a little off, but it's not. It drives straight, but just going to get it done just in case.
