Not what I mean, just talking about the turbo itself. If you look on a journal-bearing turbocharger it'll just have an oil inlet (high-pressure feed line) and an outlet on the opposite end (low-pressure oil drain or return). On a ball-bearing unit there will be 2 additional perpendicular holes for coolant to pass through the center section.
The picture below shows a Garrett CHRA (like a GT35R) with the oil feed at the bottom, the middle is one of the coolant holes, and at the top rotated out of view is the oil drain/return. I don't know why they took the picture this way but this is the exact opposite of how it should be mounted in the car.
