- Dallas, TX
- 2007 FX35 RWD
Tires are not a good fit? So did you have the wrong size (what size did you have?), or are the parada's not good for the FX? That contradicts just about every owner's statement...
Once again, what size was the tire?I felt the same regarding the "not a good fit" reply I received from Corp. Yokohama. I replaced the brakes & rotors as well as the hub checked at dealer. Yokohama also stated that the tire is too heavy for the vehicle...never heard of that one either. Big O suggested the Michelin Latitude as a replacement...does anyone have a comment on that tire or any tire that would be comparable?
Yeah, I'm assuming something might have been wrong with the size, which is why I keep asking what size was used.Maybe the tire he bought was too wide for the size of his wheels...
maybe you should just purchase the 2009 fx35 tires/rims like the ones you used in step 2. I mean, if it works for you i say go for it rather then continuing to spend $$ to find a solution. good luck with everything
I have a long lasting vibration issue as well. Here's what I'd recommend in your case:
- Do NOT pay anymore for balancing, alignment, tires or wheels. I paid a fortune and as far as I understand from your case, it won't solve your problem. Didn't solve my problem as well..
- Get the dealer measure the front and rear hub bearing assemblies. They should have a tool to measure play in those. If there's play, if you still have warranty and if the dealer is nice, they should replace those under warranty. I replaced 3 of mine, didn't solve my issue but still it might for you.
- An additional bullet for the one above: the play in hub bearing assemblies is a known issue. Many people changed their bearings.
- Get your steering wheel adjusted: There's a bolt on the steering wheel rack that adjusts the steering wheel stiffness. Get the dealership adjust it 1 tick at a time and test your ride to see if there's any improvement. They might say that "oh the steering wheel won't turn back to it's original position on a slow (like parking) full turn". That's not the case. I got mine stiffened three times. Now I only have vibration after 90mph
- If none of the above works and if you have warranty, get your drive shaft checked.
hope it helps..
