- 2017 QX70S
- Name
- Andy
This one of the easiest mod to date! All plug & play.
Drill a hole to securely mount the chip rather than using the supplied double sided tape if you chose.
I have been running with the chip for about two months now. My initial impression was, I notice all
my mods are working smoothly in harmony since the install of the chip. I have not taken my car in for
a dyno to get some concrete number on gain. I will update this DIY when I have that done.
The chip comes with a base map for basic intake and exhaust mods.
You can switch from the "Regular" map to an "Aggressive" map via a toggle switch.
Map change on the fly is NOT recommended with the toggle switch that it comes with.
You can buy a fancier Map Selector switch from Unichip to change map on the fly if you chose.
