- Portland, OR
A perfect vacuum of 0 is only going to be acheived in sapce...
It was just a reference point for the example.
---------- Post added at 08:45 AM ---------- Previous post was at 08:09 AM ----------
Max vacuum at sea level is 29.92in Hg =14.69533223463184lbs per sq in.
I used 15lbs per sq in to make the math easier. Its close enough for the example.
---------- Post added at 06:42 PM ---------- Previous post was at 06:25 PM ----------
Yeah, what MTN said.
I was just trying to give John a quick and dirty indicator test to see if his current set-up would work.
In terms of the pressure exerted on the inside of the pot, it sounds a lot worse than it is. True, the pot could catastrophically implode, but it's much more likely to do what we call, "leak before burst". Meaning, it will crack, slightly deform or fail at a seal and never get to that "implosion".
First, isn't the possibility of a catastrophic implosion enough to warrant extra precautions?
Second, with the ISS stuff you deal with parts and materials that are very precisely engineered for the task at hand. (I used to be in structural engineering and worked on multiple SLC (Space Launch Command) projects in Cape Canaveral and Vandenburg AFB) We are talking about a pot made to cook spaghetti here, not a purpose built chamber. You cant speculate with any kind of real accuracy what it will do under what MIGHT be an incredible amount of force relative to its intended use.
The reality is that this current set-up should work for the purposes John is looking for. Even the food vacuum sealers don't suck nearly as much pressure as this one is capable of, but would probably work for setting these reflectors. You just need a differential so that the air wants to move from high pressure to low pressure. A perfect vacuum is not possible, but it's not necessary either.
Didn't turbo say he needs to pull 29"?
---------- Post added at 06:46 PM ---------- Previous post was at 06:42 PM ----------
...... who's taking bets as to weather the gas line crushed or not? :tonguey:
I'm betting that you were careful and did not pull enough to collapse the hose.
