Transmission problem
Dealer wont touch it, but Why not rebuild the one you have?
Who can rebuild? This 6th gear ratio problem can be a safety issue as well spoke to corporate too. This transmissions are tricky and some times they guess when shifting . My transmission does every 3 months it seems I change trans fluid every 60k
Finaly find some time for my car, I took my car from one performance garage and will send it to another somewhere next week.
Have completed my recent mod with GTR manifold conversion using lower intake conversion from RJM with fuel rail mods and bigger injectors.
Also, done a fuel retuern line in this mod.
The reason I wrote in this post is because the issue have been happening more frequently recently.. and below is some code that my car is throwing.
Will send to another shop to check all sensors and will feed you back once I resolved it.
Discovered something new today about failure to shift or stuck in one gear today.
The camshaft position sensor is used by the transmission to know input shaft speed.
So if your camshaft position sensor is intermittent it could throw VDC, SLIP, and Service Engine soon and cause intermittent shift problems. Will do diy to change out left bank sensor.
OB II Code PO345
