3.5L Transmission problem
Discussion in 'QX70 Engine & Drivetrain' started by TheRurouni, Oct 5, 2016.
  1. Hey guys,
    Am facing a problem with my transmission, after I installed everything fixing the turbo kit and try to break in the engine after the rebuild.
    Yesterday I drove about 50 km the AT did disengaged as if it is in N but it was
    In D in the middle of the road. I tried to change from D to R to D again but again same problem.
    Turn off car then started again it worked fine but same thing happened
    to me today.
    What do u think is the problem, could the solonied be the problem
    Seems it is electrical issue although some smell coming from the car but it might be due to diffferent issue am facing ..
  2. gto
    gto Track Ready Moderator
    16,501
    529
    Los Angeles, CA
    05 FX35 RWD
    Could just be me, Love to help, but I honestly dont understand what you're saying
  3. myron02
    myron02 Member
    631
    24
    Canada
    2007 fx35
    installed the turbo and now transmission not working?
  4. OP
    TheRurouni
    TheRurouni Member
    My apology, I was writing in hurry..
    Working on my project the twin turbo.. kit now is installed, engine rebuild completed..
    So yesterday I took my car from the shop to have a test drive and break in for the engine to make everything is right before doing the tuning..
    I drove my car for about 50 km, it was working fine.. suddenly transmission stop working and not responding like if it is in neutral ( N) while it was in D...
    Stopped the car try to drive it again after shift it to reverse ( R), it worked for 200 m, then same problem again.
    Stopped the car, turned off.. turn it on again then problem gone !!!!!
    Today, the same scenario happened again after driving it about 40 km...
    I am thinking that it seems an electrical issue, but not sure, what do u think the problem ?
    Solenoid will it cause such a problem?
  5. gto
    16,501
    529
    Los Angeles, CA
    05 FX35 RWD
    And not engaging at all after 50km. Reset, then you get another 50km out of it before it happens again. & you do not feel any slip or partial engagement after it errors . . even if you give it some gas. This is what I'm understanding
    Also, what are your dyno numbers, & have you done any other mods to the tranny?
  6. Kanedean
    Kanedean Premium Member Premium
    332
    31
    Peace River, AB
    2013 FX37 AWD
    That is odd indeed. Is the engine with the turbo kit tuned?
    Is the transmission over-heating due to the added engine power?
  7. illestFX35
    illestFX35 Member
    700
    144
    Los Angeles/Glendale
    2010 FX35 RWD
    The tranny should handle it fine because you shouldnt be on full power anyways during the break in period. From what I am understanding, there is a hesitation at a stop? And is there hesitation or like clutches slipping in between gears? Odd but I hope you figure it out...
    Obsedian and TheRurouni like this.
  8. OP
    TheRurouni
    TheRurouni Member
    Engine not tuned yet, still need to drive it at least 600 km+ due to new Pistons then will do the tuning..
    Transmission over heating should not be a problem at this stage. However I removed the radiator and did a mechanical cleaning for internal tube. I found them blocked even it was changed last year, I return it back to shop and told them to install Transmission coolers...
    After a couple days will have another test drive and ll c.
    Am not sure if I ll solve the problem or not, cuz after turning the car off and started again, problem go and car work fine.. if it is due to overheating.. transmission should not work fine again after turn it off and on again...
  9. OP
    TheRurouni
    TheRurouni Member
    There is no hesitation in gear change, ut was working fine suddenly while driving RPM goes up on gas pressing but no respond from transmission like if it was in neutral ( N )
  10. OP
    TheRurouni
    TheRurouni Member
    I did not reset it, only turn engine off then on again.. yes correct it is not engaging.. even tried to change
    To DS mode but did not change to DS or Manual mode ..
    Car not tuned yet..
    No mod or upgrade to the tranny
  11. myron02
    myron02 Member
    631
    24
    Canada
    2007 fx35
    sounds to me that's an electrical issue of some sort.
  12. gto
    16,501
    529
    Los Angeles, CA
    05 FX35 RWD
    yeah.
    2nd gens. wasnt there a flash or something you can do to it.
    & you say blocked. Seperate Cooler is a great idea . .for anyone.
    You can also have them check for contamination. Coolant with oil. to guess at the condition of the clutch pack. Might need a rebuild
  13. shadow191
    shadow191 Premium Member Premium
    4,077
    310
    Atlanta, GA
    2007 FX35
    It does sound like an electrical issue or a solenoid/valve body issue. It's not slippage or heat if you can fix it with a reset. Is it throwing a code? Are you getting a check engine light? I had a solenoid fail on a valve body once and it immediately threw a code and the transmission went into limp mode and locked into 4th gear. If I restarted or cleared the code with scanner it would work again for a little while.
  14. OP
    TheRurouni
    TheRurouni Member
    This what I was suspecting at first, but no check engine light neither codes are appearing..
    I will have another test drive next Tuesday and will c how it will go..
  15. r1cky
    r1cky Member
    37
    71
    Los Angeles
    2010 FX35
    Ricky
    TheRurouni, any updates with the transmission problem? today the same thing happened, was driving in traffic, and all of the sudden sounds like it popped out of gear and stuck in 1st gear, won't shift into 2nd... had to pulled over, restart the car then it drives fine (2010 FX35 w/ 132000 mi, just changed the transmission fluid at 120k)
  16. jumbosrule
    jumbosrule Premium Member Premium
    2,843
    65
    Redondo Beach, CA
    2003 FX35T
    Brad
    Guys - this is a Transmission Control Module fault - TCM. Resetting the ECU will clear the fault but it will not stop it from happening again. This is either electrical or a transmission sensor failure - intermittent for now but I would guess it continues to get worse until you can't get it into gear at all. The TCM is suspect.
