okay I change my transmission fluid this is how you do it. first during the pan. you will need help for the second step.their is two lines that's going to the radiator.remove both of them prepare for transmission fluid to come out of the radiator and the hose.the hose that's on the right side of the radiator put it in a one gallon milk bottle. this is where the other person come in handy.while you are under the car with the line in the milk bottle have the other person turn on the engine for 3 seconds and turn it off.this will remove the rest of fluid that's in the torque converter.do this procedure until the fluid that comes out to host comes out with bubbles.when all is finished putting everything back together and services the transmission per the Manuel.for legal purposes this is just my opinion you are responsible for your own actions
Sent from my SGH-M919
