onthemove
ELECTRICAL/TCM related codes that replacing the Valve Body WILL NOT correct
P1710 - ATF Temperature Sensor Circuit P0717 - Turbine Revolution Speed Sensor
P0740 - TCC Solenoid Circuit P0744 - A/T TCC Solenoid Voltage Function
P0745 - Line Pressure Solenoid Circuit P1752 - I/C Solenoid Circuit
P1754 I/C Solenoid Function P1757 FR/B Solenoid Circuit
P1759 FR/B Solenoid Function P1762 D/C Solenoid Circuit
P1764 D/C Solenoid Function P1767 HLR/C Solenoid Circuit
P1769 HLR/C Solenoid Function P1772 LC/B Solenoid Circuit
P1774 LC/B Solenoid Function P1815 Manual Mode Switch Circuit
P1841 ATF Pressure Switch #1 Circuit P1843 ATF Pressure Switch #3 Circuit
P1845 ATF Pressure Switch #5 Circuit P1846 ATF Pressure Switch #6 Circuit
Hmm ... copied & pasted above from sonnax. p1754, 59, 64, 69 are my lucky 4 & replacing the v.b. will not correct these? One more notch under level 10's belt that tcm is at fault.
