Thule Vector M with OEM Cross Bars
QX70S
Tampa FL
17 QX70S
Reuben
The availability of subject matter regarding cargo boxes that fit our vehicles is rather limited. However, one can still find images showcasing various cargo boxes mounted on FX/QX models.
Regrettably, I was unable to find any information regarding whether the OEM fixed point cross bars can accommodate these cargo box options.
The answer to this query is quite straightforward: the fixed-point X-bars significantly restrict your choices if you wish to maintain hatch clearance while mounting a cargo box.
For the sake of aesthetics, I made the decision to purchase gloss black fixed point x-bars, unaware that my options would be limited despite my diligent research.
As it turns out, the Thules Vector M and the Motion XT M can be mounted on the fixed point X-bars, but only at their maximum adjustment limitations. This means that the internal cargo box rails will not slide any further once they are seated on the X-Bars.
Initially, this limitation seemed like a dealbreaker, as I believed that I would not be able to access the cargo area due to the hatch not opening wide enough.
However, upon closer inspection, I discovered that with the Vector in its maximum forward position allowed by the fixed point x-bars, although the hatch does not open fully, it opens enough to comfortably access the cargo compartment without hitting my head (I am 5'9).
The X-Bars I purchased are Gloss Black Reinforced Aluminum OEM replicas with a weight capacity of 225lbs.
Overall, I am extremely satisfied with the construction quality, fitment, and aesthetic appeal of the X-Bars and the Thule Vector M.
Link to OEM x-Bar Replica
Fit for Infiniti FX 35 37 50 QX70 2009-2018 Roof Rail Rack Cross Bars Crossbar | eBay
