FX35 The solution to your broken cupholder ends!
Discussion in 'FX (03-08) - Interior & Exterior' started by Themechanic, Dec 6, 2017.
  1. Themechanic
    Themechanic The World Is Yours Premium
    1,838
    184
    Boston ma
    Car:
    2014 qx70s
    Name:
    Edwin
    So what you will need is a standard coat hanger. A 3/32 drill bit. A pair of pliers to bend the coat hanger & a dremmel with cutting bit or shop cut off tool & plastic weld apoxy. So all you basically need to do is drill a hole on the inside of the lil bracket that has the spring on it & then cut out guide channels for the coat hanger wire piece to sit on there stronger then once youve got it all lined up mix some plastic welder apoxy & smooth it out on top of the inner gaps. Let it dry then carefully open up the cup holder piece while you pop in the spring loaded piece back in. Then youve got yourself a new cupholder! :cool:
  2. Ed@TunerStore
    Ed@TunerStore www.tuner-store.com iS VIP
    11,081
    540
    Miami
    Car:
    2004 Infiniti FX35 Supercharged
    Thanks for sharing!
  3. OP
    Themechanic
    1,838
    184
    Boston ma
    Car:
    2014 qx70s
    Name:
    Edwin
    Anytime! I felt everyones frustration once my drinks kept spilling because of this issue & i coudnt find a used one without buying the whole center console. So i figured id rig something up.
  4. Infiniti2011FX35
    Infiniti2011FX35 Member
    14
    2
    Toronto
    Car:
    2011 FX35
    Name:
    Omar
    Mine broke after 1 month exactly lol.Sh#$$y design
  5. Cruiser
    Cruiser Infiniti fan for life Premium
    4,339
    177
    Katy, TX
    Car:
    2007 FX35 AWD
    Nice fix. Thanks for sharing.
    Mine had the lid not locking anymore and is now permanently open. Anybody did a DIY on it here?
