The Random Question Thread
What modification is needed? I'm looking for the best sounding :)
For an FX45, get the Manta Ray from Slamming45. He developed the intake kit specifically for the 45.
Check the for sale in the vendor section
Sent from my GT-P5113 HD
Hey guys so i wanted to reclean my throttle body, last time i cleaned i didnt open the valves. This time i want to clean the inside of the butterfly valve. Mechanic told me that its better to open the key to on postion which will open the valve and clean it this way, instead manually opening it. Also, he said it will throw SES light but i can reset that light with a obdi tool. You think this could work?
i took my out, unplugged and unbolted and cleaned it manually messing with the butterfly. No problems after. I was careful when closing it but other hten that i went to town.
I'm 150-160lbs, can I stand on top my car to record a video?
Not if you will be dancing.
If you can put some thing on the roof (like a blanket, then plywood) it will better distrubute the weight. Try to use the rails and stay off the center as I can see the center popping in easily.
Will be installing pretty soon: coilovers, new rotors/pads/calipers/brake lines, hub bearings all around. Any recommendations what else to replace while doing these upgrades/repairs?
Sorry, I meant that I will be installing the Akebono Calipers:ninja:. Misread Dave's question
