The Random Question Thread
Anyone know which wire is power for the headlight harness?
square dark gray connector(dtrl?) - black(neg?) and red wire(power?)
Ballast wire - black (power?), green ( neg/ ground?)
Here ya go:
Driver Side:
Passenger Side:
Yeah, you can also just wear it around the yard to freak out the neighbors.
Hahaha, I'm sure walking around with that mask on will certainly freak out the neighbors. Nothing heavy duty in the painting dept. yet! Just some planning for now! I bought some paint and an el cheapo spray gun to test on headlight shrouds for now. Eventually, once I got a hang of things in this area, I would work on the side skirts that comes with the front bumper when Ed bought the kit.
I suspect after about a year the garage will be converted into a paint shop.
if you buy that supercharged FX, you just need to repaint the side skirts diamond graphite=)
I know there's a thread for bikers (which I thought was a 'sportsbike' thread lol)
But are there any runners here?
How far and how fast can you go on your spare tire? Also, what pressure should the spare tire be at? My rear passenger tire is done. So I'll be riding 3 22's and 1 14" on the rear.
I need to go about 90 miles, should be safe?
Tapatalkin'
I went 65mph for 25 miles on mine, all hwy, with 3 22's.. Zero issues! Not sure of the pressure, buts its usually high.
Evasive maneuvers with a spare is where you get in trouble quick. 90 miles, I'd go as slow as you can handle. The psi recommendation is listed on the tire.
SfmDRuT2
Thanks, getting it out the spare now and it says 60psi. Mine was at 14psi.
Suggest everyone check their spare tire pressure to to make sure your spare is safe when you need it.
Tapatalkin'
I know a guy at the 1/2 way 45 mile mark if you need a pit stop. It's a good exit repairing broken studs too. :wink:
Go slower than normal and you'll be fine. (I'm sure you're getting about ~46 lbs of air first).
