- 2017 QX70S
- Name
- Andy
George, part of your question has been answered in another thread you created.
https://www.infinitiscene.com/search/1/?q=21636-Fx35
21741 CG000 for the hose and 21750 15U01 for the clamp if you need one.
I noticed the drawing showed 2 clamps, one at the radiator cap connection and one at the reservoir connection, which I thought was interesting because I only have one at the radiator cap. I double checked 2007 since I selected 2004 when looking it up for your year, and noticed it said only 1 clamp needed, but said 2 needed for 2004. I don't know if the tank spout design was changed to hold the hose or what exactly.
I should be able to use the clamps I already have on my current hose correct?
Yeah I would think so as long as they still hold tightly. It looked like mine had dug into the hose, so it should hold even better on a new hose, unless the indention is built in.
Dumb question:
Do we change the ATF fluid even if we have an RWD vehicle?
Will the ballast from a 2004 Murano SL fit and match the OEM ballast in a 04' FX35? I believe it will as it says bi-xenon. Just want to double check before I purchase.
