The dreaded "empty fuel gauge" when full of gas
2011 FX35
Milton
wondering. When i am replaceing the fuel sending unit and the fuel pump assembly do i have to set the floater arm in any way?? I changed the fuel sending unit on my 2011 FX35 lastnight and it did not fix the issue so im going to replace the fuel pump assembly with the attached sending unit this wknd..
What good timing!! Happened to me Friday.
I skimmed the forum and it Appears some kind of retention clip is under engineered and allowes the sender unit to twist and get stuck.
I haven't screwed with mine yet, but why don't you be a pal and let me know what fixes it? Hell maybe even a picture :P
So based on the TSB I found on ALl Data DIY (Shows how to pull fuel pump and fix) - This can be fixed for 47$ in parts. Im placing the order now. Follow the first link I posted cause thats where Ill post if it works or not.
