Ok, here is my DIY OCC photos:
Here is the 1/4" air compressor filter I chose to use, with the fittings already attached and sealed with RTV that has been curing for a couple days.
I didn't like that the drain on it was essentially uncontrollable. It would randomly stop water from draining when you turn this little knob, but wasn't reliable at all, so I just plugged both sides with RTV.
I use the holes on the filter to attach screws, washers, and zip ties for my mount.
Chose this location to mount it, and drilled 4 holes.
Threaded the zip ties through and attached. Also had 2 zip ties together go around the actual OCC to provide support should the other ties break. Also ran another 2 ties through this extra support and around the grounding wire to provide more extra support.
Here's the hose that comes off, already removed. Goes from the yellow nipple to the long pipe out of the front of the plenum.
All mounted up and attached. And a final shot of everything, with the Z-tube I put in afterwards.
If I were to do it again, I would go to Harbor Freight for the can and gold fittings because it was a lot cheaper there. Not sure if they had any hose though.
