No, the stock intake has only one vacuum line but there's no reason you couldn't add a fitting.
Best site ever for making your own intake - any size couplers, clamps, vacuum lines, fittings, etc..
Intercooler Pipe Fabrication
If you just get a new silicone coupler to replace your OE coupler, you could then add one of these guys for the second vacuum source. Or install 2 of them, and cap the original vacumm source on the OE intake.
This is what they call a silicone port system - you would need to add one. I've used these on other cars.
Silicone Port System
HOWEVER...
This is probably too much time, money and effort on a stock car. No real benefit for dual catch cans in a Naturally Aspirated setup, so you would simplify it a lot by just using one can on the PCV side. Remember once you install a can... you gotta empty it with every oil change. Most Jiffy Lube places or even dealerships, wont know they need to do that.
