Throttle Body cleaning on 2005 Fx 35
You need:
10mm socket
5/16 socket
3/16 hex bit
TB Gasket (16175-AR000)
Carb cleaner
1) Remove the engine cover
2) Remove the air duct 2 clip, one bolt, one hose
3) Remove the TB 4 hex bolt. All bolt are the same no need the remember position. 1 electrical connection.
4) Clean TB with carb cleaner and a light brush (tooth brush)
5) Clean the intake since you got access
6) Clean the area where the gasket seat
7) Put back gasket and TB torq the 4 bolt in a clockwise patern to make sure the gasket seal. Don't forget to reconnect the TB wire.
8)Put back the intake duct
9) Start the engine and spray some carb cleaner one the TB gasket. Nothing should happen if the engine drop rpm thats mean the gasket don't seal right.
10) put back engine cover and Voila!
You need:
10mm socket
5/16 socket
3/16 hex bit
Carb cleaner
