Speedometer light....
carl292
Odessa
Fx35
Hey guys, took my daughters car for a ride last nite and noticed the speedometer light on the top is out. Is this an easy fix? Searched cluster and no results. Thanks
http://uploads. -cdn.com/20161108/e1a4c3dd1bf49e1e2e36b1a47f046729.jpg
1) Replace (desolder & solder) the LEDs; reference this post I see BLUE!!!!
2) Replace the odometer cluster with a used one easily found on ebay. Keep in mind though, you will inherit the replacement odometer mileage. Spend more $$ to get the replacement odometer reprogrammed to your original mileage if you insist.
