PEEJ
Weeeeeeee!!!
- 2014 QX70S 5.0
- Name
- Patrick
I dropped the QX off at a local tuning shop to start the custom intake/exhaust modding process. I love my ride, but the QX70, even at the level of the 5.0, is just much too quiet for my tastes. I'd argue that the OEM exhausts compared between the 3.7 and 5.0 are nearly identical in the type of sound generated. It's time to do something about it.
The plan:
Here are a few questions that I see coming my way with regards to #2:
Completed aluminum intakes:
Completed ARK GRiP exhaust and GTSPEC rear lateral brace install:
Next up, stainless steel test pipes complete with start up, rev, and launch videos. Stay tuned...
The plan:
- K&N drop in filters
- Create a custom intake that gets rid of the OEM intake baffling in favor a less sound restrictive aluminum tube complete with mounts for the MAF sensor in favor of an aluminum mandrel.
- Install ARK GRiP Exhaust System
- Install custom stainless steel test pipes
- Osirus Uprev Tune because it'll really tie the room together
- Will this net you any increase in horsepower? No.
- Even with a tune? Doubtful, as I am reusing the OEM airbox which already acts as a functioning CAI and the aluminum tubing is the same diameter as the OEM intake tubing. If there is any power to be gained, it will be probably be so negligible that it will never be noticed.
- Then why do it? Done solely out of the curiosity of discovering what kind of exhaust note is hidden within the VK50. At 390 hp, the 5.0 is significantly quicker off the line than the 3.7, and with 369 lb-ft of torque compared to the 3.7's 267 lb-ft, it's not even fair to compare the two together. But what's up with the exhaust? It sounds like I'm driving a Buick! Not for much longer.
