What 22 wheel were you entertaining?
I think that's the right call cuz it'll look hot. If you're gonna go all season with the 22s, you should research the tire well. I think the pirellis are good in all weather. Expensive, but great tire.
The spideros are gonna look pretty huge not having a lip, & the offset on the 9 is 38. Could really be more aggressive than that. Also will look better with a BBK on those.
I vote the EXEs. Carlos's ride looks exceptional. What about those silver Ordens that someone posted up here on the board?
If you need a PS comp done on anything, LMK. Might help you decide
Ultraleggeras are very cool, but you're gonna regret all that money, & then sittin on 20s.
& which Rays?
Just a thought though. The 9s have an offset of 38. That'll probably need a spacer to look right unless you oversize the tire. You may want to entertain the idea of getting the 10.5 & H&Rs that dont sit quite as low. You may need a little trim (who doesnt from time to time), but that would probably look the best.
Have a question here. These are the two results for same comparison on offsets and clearance:
from wheelsmaster:
Wheels:
Wheel sizes: 20x8 ET 40, 20x10 ET 42
BackSpace:154 mm (6''), 181 mm (7.1'')
27 mm (1.1'') deeper.
Rim Lip
23 mm (0.9'') wider
from 1010tires:
Inner clearance: 27mm LESS
Outer position: EXTEND extra 23mm
What's the problem here? In the first one, it says it's 27mm deeper, in the second one it says 27mm narrower??? This wheel is a lipless one so the offset type will be positive I believe. Does the 1010tires calculator calculates the negative offset and the wheelsmaster calculates the positive? Is that the problem?
Why would it look good with an oversize tire? Didn't get that..
It's just semantics, both show the same info but word it a little differently on the suspension clearance.
Many wheels for drag racing and stuff don't come in offsets, they come in backspacing. http://www.jegs.com/p/Mickey+Thompson/763735/10002/-1/36676
ok, got it now.. That said, the gianelle spideros in 20x10 probably won't fit my stock brakes.. just got excited for a moment.. :frown: Looks like I'll get the 22s.. Gotta empty the storage.. It's full of tires & wheels... Anyone want a 275/45/20 set or the stock 18" wheel-tire set?![]()
