UPGRADES UNDERNEATH; Invidia dual exhaust, Transgo reprogramming kit, H&R drop springs, Kinetix high flow cat. converters, wrapped mid pipes, 1/2 wrapped catalytic converter heat shields and parachute bumper delete red-neck style.
Fastest N.A. FX35, FX45, FX37 & QX70 V6 on the planet?
Street - 0-60 in 5.2 sec. & 1/4 in 14.0 @ 99 1/26/18 (2/10's Scangauge corrected)
Strip - 14.3 @ 97 mph 4/28/18 (Density altitude corrected) D.A. 1,700/Temp 78*/Baro Press 30.15/Elevation 400'/Humidity 56%
Youtube street run prior to completion of intake mods, headers & final tune (5.8 0-60 & 14.4 1/4)
Dragtimes fx35 list (#2 MJH)
Fast Infiniti FX35s 1/4 Mile 0-60 Drag Racing - DragTimes.com
My Dragtimes page 2003 Infiniti FX35 All Wheel Drive 1/4 Mile Drag Racing
15% MD500 dyno correction = 251 awhp/231 awtq. Approx. 348/321 @ flywheel.
WEIGHT REMOVED; (stock 4204 dry & 4375 w/full tank) WEIGHED 3926 AS OF 5/13/18 / REMOVED 280 LBS
wheels, tires, brakes, brake lines, suspension springs – 87 lbs., High-flow cats & V plenum - 13 lbs., Spare tire & tools – 65 lbs., Sway bars & hardware – 36 lbs., Misc. brackets, hatch seat belt, transmission weight – 16 lbs. ,U.D. pulleys – 6 lbs. ,Exhaust – 5 lbs., Original floor mats (were under stock rubber mats) & spare tire cover – 35 lbs., Washer fluid res. & idler pulley deletes – 6 lbs., Coolant bypass hoses & brackets, oil filter heater & wire tuck brackets - 7 lbs., Horn, bumper guard bar, 5th head rest & grill swap – 3 lbs., SCOTABC mat swap - (8lbs scotabc 14lbs stock rubber) - 6 lbs., Exhaust wrap & shields - + 4 lbs
INSTALLED PARTS & COSTS;
SUSPENSION - Camber & bit $132, Springs $278, Shocks/struts $260, Front wheel bearings $160, Axle seal $10
Total - $840
WHEELS & BRAKES - Advanti $755, Lug nuts $65, Spacers $272, Conti tires $1000, Powerstop rotors/pads $380, S.S. lines $125, Caliper G2 epoxy $55, Tires trued $160
Total - $2812
ENGINE - UR Pulleys $330, V plenum $255, Uprev software, tune & pulley install $1015, OEM O2's $340, Oil C.C. $120, 4" Intake + misc. $250, Tune/knock sensor $440, Iridium plugs $60, Radiator $105, Tensioner pulleys $70, 75mm T.B. & plug $190, T.B. adaptor plate $140, Wire tuck $100, Aramid gasket $40, V stack & huge filter $120, 3rd tune $265
Total - $3810
DRIVETRAIN - Shift kit (including oil & botched job by me) $950
Total - $950
INTERIOR/EXTERIOR - Windshield $300, Hood lifts $50, Fuel cap & clips $22, Leather repair/dye/prep $175, PDR $225, Grill $172, DIY Paint correction $200, Door actuator fix $80, Vinyl wrap trim $100
Total - $1329
EXHAUST- INVIDIA $850, HFC $400, Tomei headers $860, DEI wrap & shield $140
Total - $2250
MISC. BULLSHIT - $300
TOTAL AS OF 5/13/18 - $12,290
SIMILAR COMPARABLES;
2003 FX35 AWD 5 spd Transgo VQ35DE (onthemove)
3,926 lbs, 348/321, 0-60 5.2, ¼ 14.0 @ 99 mph, 255/55/18, 29.0"d.t., 11.1 lbs/hp, trans 1st-3.54 2nd -2.26 3rd-1.47, F.D. 3.88
Drag Coefficient Cd = .35
2013 G37x AWD 7 spd slushbox VQ37VHR
3,823 lbs, 328/269, 0-60 5.5, ¼ 13.8 @ 100mph, 225/55/17, 26.7"d.t., 11.7 lbs/hp, trans 1st-4.92 2nd -3.19 3rd-2.04, F.D. 3.36
Drag Coefficient Cd = .29
2017 QX50 AWD 7 spd slushbox VQ37VHR
4,019 lbs, 325/267, 0-60 5.7, ¼ 14.3 @ 97mph, 225/55/18, 27.7"d.t, 12.4 lbs/hp, trans 1st-4.92 2nd-3.19 3rd-2.04, F.D. 3.13
Drag Coefficient Cd = .33
2017 QX70 AWD 7 spd slushbox VQ37VHR V6
4,321 lbs, 329/267, 0-60 6.2 ¼ 14.5 @ 94mph, 265/60/18, 30.5" d.t., 13.3 lbs/hp, trans 1st-4.92 2nd-3.19 3rd-2.04, F.D. 3.69
2017 QX70 S AWD 7 spd slushbox VK50VE V8
4,508 lbs, 385/369, 0-60 5.3, ¼ 13.7 @ 101mph, 265/45/21, 30.4"d.t., 11.7 lbs/hp, trans 1st-4.89 2nd-3.17 3rd-2.02, F.D. 3.54
