Oil Leaks - Somebody please help me
Man, there is comparison of the two valve cover that I have posted on here. Need to find that. Anyhow, I know the Max valve cover does not work on the FX.
I bought a Maxima cover to try out and know for sure it does not work for the FX. It is still in my basement if anyone want to try it. :smile (2):
Do you have one side or the pair? Can I have it [emoji1].
The pass side should bolt on directly. A red/AWD vq35 is all the same, if it worka for the g35 guys, it should work for a fx. But the driver side will need custom work, like extending the wires to coilpack 6 and etc.
so did the job myself took about 4 hours broke a hose connected to the valve cover on the top side replaced it with a hose from autozone ran it runs good so far but this morning i turned it on and was good i stopped by gas station to get coffee and when i turned it one it sounded like it was on but had turned off i panicked and turned it on gain and gave it gas and it stayed on any ideas?
