Hi all. Gearing up to swap the FX50 style Akebono caliper/rotor set up on my '12 FX35 LE.
I already have purchased the calipers from a '13 G37s, the Z23 PowerStop rotor & pad kit as well as the SS brake lines from Stop Tech.
A few questions...doing searches there is no real clear answer....
Dust shields....
Spare Tire....
Thanks for the help!!
Dust shields....
- Will the stock front FX35 shields clear the larger 14" rotors or will the lip have to be cut off?---CONFIRMED FX35 & FX50 for 2102 share the same front shields (41161-1EX0A LF & 41151-1EX0A RF)
- I'm 99% sure that the rear shield lips must be cut off-- CONFIRMED FX35 & FX50 DO NOT share the same shields & must be trimmed
- The stock FX50 uses hard lines to connect to the Akebono calipers. Using the SS braided StopTech hoses require the use of a banjo bolt...do these bolts with the brass washers now bolt in place of the metal hard lines in the rear of the caliper or is there an adapter of some sort needed? Any pics of the connection on your SS lines?--CONFIRMED you can use the SS or stock banjo type connection with the Akebono's
- I have read conflicting stories from some users that the bolts that come with the SS braided hoses are too long....some say they work perfectly. Most sat the stock bolts are too long as well. Do you have to "cut" these bolts?---So far it seems hit or miss... 2 bolts in one of the package were 2 different sizes....too long. Ordered all 4 from Concept Z Performance...shorter length
- I did get an answer to this question from member RipNFX...he stated the 21" Turbines will clear the Akebono's no problem...no spacers needed. This is for future searchers...--seems like this video is proof that the Turbines WILL fit...
- Also confirmed using Concept Z's templates... (not my pic or wheel...this is from their website)
Spare Tire....
- The stock FX35 spare (that I have even with my factory 21" Turbines) wont work on the front but probably should on the rear using the templates
