S Matic is fine. Been running with it for a few years now.
I have a question for you guys. I wanna do the drain and fill today after work so I am looking to buy tranny fluid. I want to know how much fluid I need for this? I don't wanna buy too much and have it sit there for ages. This stuff isn't that cheap here, it's about 25$ a quart.
Buy 6 quarts. You will likely use between 5 and 6
That's fine as long as Matic J is in there.
so should I get one of those 5L jugs or 2 just to be safe?
I would get 2 just to be safe....then you can also use it for the transfer case...you might as well drain and fill that too while
your under there.
yes I was planning to get the transfer case done as well. I just don't know if I should get 10L, or 5L for tranny and a quart for the transfer case.
When I did it I ordered 6 qts and it was just enough for both...the transfer case took about 1.5 qts
6 quarts for everything, or 6 for transmission and 1.5 for transfer so 7-8 total?
I went to walmart and they didn't have any fluid at all in store even tho site says they do so now i have to buy castrol at 10$/quart or mobil 1 at 15$/quart
It was 6 qts total....I just filled what I had drained out and measured and it was about 4.5 qts. You are just draining and refilling not a complete flush.
Maybe get 7 to be on the safe side...I did use every last drop I had.
