doubleeckz
- Ontario
yea, i would love a drop too, not in the budget anytime soon though :.frown:
Also did they use hub centric rings to mount your wheels so that it is compatible with the Infiniti hub size of 66.1mm. If they are not used with aftermarket wheels(which usually have a much larger hub bore so they can be used in other applications) then there can be some unbalance because the wheels aren't centered perfectly.got a question, after getting the install, my steering wheel vibrates left/right when im between 60-75mph. I know that I was going to sacrifice some ride quality going with larger wheels, but this seems a bit drastic. Is that due to poor tire balancing job? slow speed or speeds past 80mph it smooths out. How do I get it to stablize?
They were there, now they are gonnoCan't see any pictures:squigglemouth:
