New Wheels - Dropstars DS41
got a question, after getting the install, my steering wheel vibrates left/right when im between 60-75mph. I know that I was going to sacrifice some ride quality going with larger wheels, but this seems a bit drastic. Is that due to poor tire balancing job? slow speed or speeds past 80mph it smooths out. How do I get it to stablize?
Also did they use hub centric rings to mount your wheels so that it is compatible with the Infiniti hub size of 66.1mm. If they are not used with aftermarket wheels(which usually have a much larger hub bore so they can be used in other applications) then there can be some unbalance because the wheels aren't centered perfectly.
thats wierd, i posted it up from my google drive account. do pics have be posted with URL only? Cant post from a file on the pc?
They look good, but because the spokes don't go to the edge of the rim (which some people like / dish / etc), it makes them look like 20's :/
that was it, put on some rings and got it dialed in. Its running beautifully. Still not quite as smooth as stock, but i guess that was expected going with 22's
