Need Torque specs for Gtspec braces
If you are talking about the GTSPEC front strut brace here is what it is for 2nd Gen FX.
I know the torque for the 3 top strut tower brace nuts on each side is 22 ft-iibs
nope I'm talking about the bottom braces. our strut bars is 35 foot pounds.
---------- Post added at 07:35 PM ---------- Previous post was at 02:55 PM ----------
Also if htere is any diy installs would be great... i lifted the fx to look, and i dont get how to install the bolts. instructions came in chinese or something..
im installing the front and mid lateral brace, rear lower tie brace tomorrow hopefully.
THese are the bolts for the mid brace. how do i put them in?
To install the Mid Chassis Brace, just position the brace and line it up the existing hole in the frame. The two rear hole need the rivet nut. The two front ones, you can slide the nut into the frame via the hole in front of the mounting hole and you can hold the nut with a wrench while tighten up the bolt. That the easy part. Ok now to install the rivet nut into the frame. Stick the rivet nut assembly into the hole, hold the long silver nut with a wrench and press the rivet nut tight against the frame and making sure it s plum and straight and crank the black nut with a socket. If you have an impact gun, use it. It will make the job easier. You stop cranking the black nut once the rivet nut is pressed tight against the frame. Undone the black nut and remove. The rivet nut should stay tight in the hole which become the nut for you to install the bolt that mount the brace. I hope this make better sense than the instruction that it came with.
---------- Post added at 10:14 PM ---------- Previous post was at 10:04 PM ----------
Just tighten the bolt. If you insist on torque it, I would suggest any where from 70 ft lb - 80 ft lb is plenty for the four bolts on the Mid brace.
The rear lower later brace, torque it to 74 ft lb. Make sure your rear wheel is on the ground, othewise your alignment will be way off. Use the DYI Jeff put together that I see you already looking at.
ill try that. the rivet doesnt seem to git in too well. i got some black undercoating which probally made the hole smaller
Yeah, clean out the hole. If you have to scrape around it which might expose some bare meta, then apply some liberal amount of grease to around the hole to prevent corrosion.
