Banjos-n-Beer
Hello Folks- when I drive over certain crappy surfaces, my Nav screen will rattle a bit. There is also a "metal in a glass ashtray" sound. I'm guessing there is a lower right hand screw for the screen, and it has backed itself out a bit, and therefore rattles around as well. I found this ad that has pics of the screen:
15 2015 Infiniti QX70 Information Navigation Display Screen P/N 28091-1JA3C OEM | eBay
Since I only have the powertrain warranty remaining, I would like to try to tackle this myself, at least at first. I'm thinking that if I can get the Navigation control panel off directly in front of the screen, I should be able to see if anything indeed needs tightening. Worse case I could wedge some felt into any crevices to keep everything nice and snug. I'm not sure if the center vents would need to come off as well in order to get into this area.
So... how easy is it to remove the Navigation control panel? Can the black bezel trim be removed with simple plastic dash trim removal tools? It then looks like there are two screws on the bottom holding the Nav control panel in place. See pic:
2012 Infiniti Fx35 Navigation System Controller 283951CA2D OEM AUTOGATOR | eBay
Please let me know if I'm biting off more than I can chew. Thanks in advance!
