last night with the wheels so much better from the upper arm mod I drove it a bit hard. once or twice I felt it bottom, I was trying to get it to hit bottom to see if it was low enough yet, if it didn't bottom then it'd still have room for drop... wasn't sure but I thought maybe it might have been the shocks bottoming but I did feel it bottom twice... I did have the air shocks all the way down at just a minimal 20psi. if it didn't bottom I would consider cutting 1/4 coil in the rear, but I was able to get it to hit bottom, so it's low enough
when I parked it I looked at the sidewall for wheel contact & didn't see anything last night so I just figured the shock bottomed. I then got a look at it during the day & I see that it wasn't the shock bottoming at all, but the tire did contact. there was no contact on the sidewall from the lip at all, the rolling was good & the tire clears it & goes all the way up into the well past the lip, the tire contacted on the outer part of the tread itself, & it contacted all the way up in the well where it curves... this mark on the tire is the factory undercoating from inside the wheelwell
this is like the perfect height, just low enough to touch occationally at 0-20psi, means it's as low as possible so then I aired up the air shocks to 70 psi, which is the middle of there useful range & the results are the absolute lowest my fx can be without touching or rubbing anywhere. the perfect height.... at 70 psi there is no contact at all & it only makes the back come up less than 1/8" from where it sits with no air, almost same height really... but firmer...
so I aired it up to 70psi, 3/4 tank of fuel, me & my son went out driving.... drove a lot, bumpy & hwy & speed bumps, smooth highways & rough roads too
the back is low, def feel that the front is up higher now....
with 70 psi in the rear air shocks the ride was very different. don't know if you'll believe me or think I'm exagerating but today my fx rides better than it has ever rode since the day I got it. took me a few minutes to realize why this dramatic improvement in overall ride, it felt so balanced & felt great, I was surprised, but then I figured out why:
when I first did my H&R's I was pretty impressed with the ride, firm but not harsh. it felt balanced & rode very nice, but was still just way too high...
when I cut the front 1/2 coil though it raised the spring rate of the front a bit, I figured it to be a bit over 15% increase in the front spring rate. after the spring cut the front did feel better, handled better & a bit more tight but you could actually feel the difference in spring rate between the front & rear, the front was slightly harsher than the rear, & it compressed slightly less than the rear. I could feel the difference, & the front & rear didn't feel perfectly connected but eventually I got used to it & it didn't seem so bad, it was a compramise to have the lower stance. the rear always felt slightly "softer" than the front though, which in itself is a feeling of front & rear not connected, for it to feel well conected they would have to feel the same and as one... but it didn't cause the front springs were cut while rears weren't...
well now, the air shocks at 70psi necissary to hold ride height are actually adding a bit to the spring rate of the rear. believe it or not, this is actually evening out the spring rate front to rear & the suspension feels great, better than before. it feels balanced, the front & rear feel like there actually working togeather better than they ever have, the ride has changed... the front no longer feels harsher & the rear no longer feels softer, the whole thing just feels really really nice & even... it feels like a big bmw sedan or something, it has never felt as good as it does now. this is a nice bonus that I didn't even calculate for or expect. this rear setup worked out to be really perfect
at 70psi the rear alignment looks very close to correct in these shots, & I think the rear looks low enough now too. in order to go any lower than this I'd have to flare the wells inside & out a bit, get rid of the moldings all around, custom bodywork... not going there for a while though I think, I think it'll sit sweet with the front dropped a bit & I can't believe how good it rides at this height. the front drop will not alter the ride quality at all as long as I don't cut the spring any more, so the front will still be another 1 1/4" down from these shots... I'm still amazed at how good the alignment is at this drop without any adjustment work other than the upper arm relocate
these shots are final rear ride height, at 70psi....
