- brooklyn, ny
I wonder how much twisting will be affected by the fact that I'll use an air shock on the front arm... I'm thinking it might actually help even out the twisting slightly... the upper arm is triangulated to resist foward & rearward movement of the upper ball joint, but like you said, the fact that the spring is on the rear arm & the shock is on the front puts a lot of twisting force on this too as it goes through the motions of ocilating up & down while driving... the rear arm is just always being pushed down while if the shock is doing it's job it'll be pulling on the front arm while extending down & pushing on it when compressing, adding to the twist you talking about I think..,
* side question... when you were considering building coil overs, where were you thinking of attaching the lower pivot of the coil over? on the front arm where the shock sits now or on the rear spring arm or ?
ok, heres a few shots of my modded rear arms & struts done, also shortened the front end links to keep the sway bar away from the axles at this drop... my fabricator left the painting for me, I wonder why?
I like the rear arm extensions being welded to the arm much better than a bolt on extension, although that would def be the easier way to do it I guess...
viet, thanks for your input, your the only one this low to see the in's & outs of this in use really so far. one more question, I see you have a spare subframe, do you have any spare sets of upper arms though to sell? if I had a spare set I could build an adjustable upper arm by building a jig from the original... would at least help a lot to be able to get the camber & toe perfect at ride height at least much easier. buying new arms just to make a jig would suck, there well over $200 each & would be useless after the jigs are built... custom upper arms might help you out too a little maybe?
