La_QX70S
I was thinking this is my next and last mod on my car.
Also if you went from your oem vq35 manifold to vq37 you should lost some hp at midrange
You can find all the part # for the braces for 2nd Gen from this thread V.Products - B2autodesigns: 09+ GTspec Group Buy
thanks, i went out to B2autodesigns, they said no more in stock and GTSpec went out of business years ago, so only if anyone is selling. I've also been chasing down Ultra Racing for their version but no easy to get in USA. The USA licensee only has certain parts and expensive. And the headquarters in Malaysia doesn't want to ship or can't ship because of COVID. Might go with the Cusco or Megan products
Lovely Mods! I have an ARK Installed on my QX sounds beautiful. Im now toying with the idea of fast cats then remap? Im just little worried about extra Boom noise. I see theat you have installed cold air filter, What's the whole package sound like? I only have replaced the panel filters, Im sure yours will be sounding a little louder!!
I install the CAI before the ARK CBE, you can hear the CAI then. Not much louder than OEM filter box, but definitely felt the difference in acceleration with the CAI. After the ARK CBE, all I can hear is the exhaust note. The ARK drone a bit more to my liking around 1.7k - 2.2K RPM. I laid down sound deadening sheets to the entire trunk, wheel hum area, and rear seats area to mass some of it. It helps a little!
I'm sure it will be much louder if you swap out the CATs.
Side fender turn signal. The LED strip with the homemade brackets are mounted onto the back of the vent in the photo for test fit only. When installing, you need to remove them off the vent. Install the vent back onto the fender, so vent would flush the fender as before and then screw the LED with the brackets onto the back side of the vent through the wheel well on the inside of the fender.
View attachment 605902 View attachment 605903 View attachment 605904 View attachment 605905
So sweet, this is my absolute next project.
Well done!
Where did you get your break pads and rotors? My rear break pads and rotors need to be replaced and not sure if to go with infiniti or different ones. Def need to find the Infiniti part numbers first to find similar ones
I have finally decided swap the OEM head unit with a Tesla style screen head unit. I have been looking at the NiftyCity unit for awhile now until I saw the exact (at least from photos) one on AliExpress for about $500 cheaper. All connections are plug-n-play. Most functions that I use daily are retained - 360 camera view, OEM reverse camera, OEM TPMS, and audio quality. The 360 camera view works when shift into Reverse, OEM TPMS works just like OEM. The audio was good; I wish it can be a little more power so that I don't have to crank up the volume as much. Audio output quality was good with EQ with DPS. One function that I miss currently was the Camera button (360 view at slow speed). I saw this was mentioned on a NiftyCity installation video. I have not been able to figure out how to get this work and have been working with the seller to figure this out. The screen was nice and bright.
Here are some photos of the unit:
20240303_224709.jpg 20240303_224926.jpg 20240304_160400.jpg 20240306_171923.jpg 20240318_142511.jpg
Updates on the Tesla style Android radio after about a month of daily use: Still loving it. Also the vendor support got back to me on the Camera button (360 view at slow speed) function I was unable to figure out. The Enter button on the steering wheel is the button you press to see 360 view at slow speed.
looking back at your alignment how did they correct the caster? from what i can tell the front megan camber arms dont have caster adjustment like the spc arms.
The caster was not affected looking at my alignment report.
I know this is an old thread, just wondering how is the radio a year after ? Do
you remember the brand from Ali?
Nifty city was the one I purchased.
Still like it but did have issues and still have issues.
Wireless connectivity probs mainly
It doesn’t automatically connect 30%of the time
It’s defo the duel Bluetooth.
Not an issue when you have a sim loaded but I’m on my 2nd cable and now that’s packed in.
It’s on the wife’s motor so I just leave it but should really sort it.
Nifty support has been taxing to say the least
