La_QX70S
Side fender turn signal. The LED strip with the homemade brackets are mounted onto the back of the vent in the photo for test fit only. When installing, you need to remove them off the vent. Install the vent back onto the fender, so vent would flush the fender as before and then screw the LED with the brackets onto the back side of the vent through the wheel well on the inside of the fender.
20200620_124248.jpg 20200620_124256.jpg 20200620_124951.jpg 20200814_195546.jpg
H&R Spring & Megan Camber Control Arm Installation. The front spring and camber arm installation is pretty straight forward. The rear is way more complicated as you have to remove many more parts.20200823_131734.jpg
20200823_140927.jpg 20200823_140935.jpg 20200823_142148.jpg 20200823_143103.jpg 20200823_174156.jpg 20200823_144002.jpg 20200823_155012.jpg 20200823_155029.jpg
Installed my own DTRL with a set of 6" LED lights. I tap into the positive wire at the cigarette lighter feed a relay to trigger the auto turn on of the lights when the car is running. I install a second relay to turn off the lights when the headlight is on at night. I also mounted a homemade bracket using some aluminum angle strip to mount the LED onto. In order to mount the bracket to the frame, the bumper cover need to be removed. Here are some photos of the installation.20201103_163159.jpg 20201103_163206.jpg 20201103_163223.jpg 20201103_163306.jpg 20201103_163655.jpg 20201103_163231.jpg 20201103_163231.jpg 20201103_163246.jpg 20201103_163259.jpg 20201103_163724.jpg
