- Dallas, TX
- 2007 FX35 RWD
Carlos has wheels that don't come in our pattern. He had them drilled to fit, I guess they were smaller at first.
Those would look gr8.
Even in Chrome![]()
Still kicking around the idea of wheels, but now I'm looking much harder. I decided if I'm going to get wheels, they might as well be custom for the perfect fit without spacers. Have no problem with going staggered. 22x10 in the back 22x8.5 or 9 in the front, but willing to listen to pros and cons about that. Also not against rolling the fender if that's what it takes, but thinking with a custom set-up that shouldn't be necessary.
1) Need spoke clearance for BBK (7mm spacers minimum work on OEM wheels)
2) Want the wheel all the way up to the fender (25mm spacers work on OEM wheels)
3) Biggest lip possible with the above limits
If I were ordering custom Infiniti wheels, I would need to order (+38-25 spacer = 13mm offset). This would get the wheels out wider to the fenders.
BUT - I need the spokes to clear the caliper, so I would still need a spacer - (7mm spacer + 20mm wheel offset = BBK clearance AND wheels to fenders). This is what I am trying to avoid - using spacers at all. How do I know if the spokes of any wheel will clear my BBK, even if I am sure about the offset?
So I just visited Tire rack and they only had seven options for 22" wheels. Didn't care for the ones they had.
