This may be getting too specific for this stage of development but wouldn't you want to run the hot and cold sides on opposite sides of the engine? I mean if your air filter is going in the drivers side fender (+1 BTW) and your plenum inlet is angled to that side as well, wouldn't you want the exhaust plumbing to be on the passenger side of the engine?
Routing will completely be determined by real estate available. If it makes sense to separate I will, but it's secondary to getting the absolute shortest pipe runs.
if your running a MAF sensor you have to put it before the sensor too, you don't want to bleed off already metered air, because the ecu will add fuel for that air & if that air doesn't make it's way into the motor then you'll wind up creating a rich condition...
EDIT - Turbo-BOV-IC-MAF, per turbo's next post...
You could always recirculate the air from the BOV. But then you'd lose that "cool" BOV sound.
In the spirit of this build, I'll probably recirculate. Seems like a waste to just blow off already cooled air, no matter how cool it sounds.
Did updated sketches cuz that's how I roll. Removed all the "bad" sketches from previous posts so as to not confuse anybody - including myself.
BOV, recirculated to the intake and MAF added for reference:
Added a single Wastegate
Added exhaust tap for Wastegate
All layers
