$23-2700 should be about right for your area. It varies a lot, in SoCal places will do it for under $2K since so much competition. Where I am in GA, everyone wants $3500+ since not a lot of shops do it. I got a quote of $1600 for labor only on my FX (I already have the material). This was from the same shop that wrapped my BMW. This reflected a discount since I've had a lot of work done there. If you do ever get it done, see what their technique is, there are a lot of corners that can be cut. Some places will do everything in multiple pieces which is easier. Some don't tuck the material, they just razorblade it at all seams. See if they use edge sealer which makes a huge difference in life. When inspecting the work, make sure you look under the car and at all areas where there is an edge. Lots of shops cut corners here since you don't see the underbody much, but if the edges start lifting, the vinyl won't last as long.
