thnx guys so the rear right worked fine after jacking up slowly and took the bolt out.. But i ran into the biggest problem with the two rear left side bolts, one for the shock the bottom 17mm and the spring carrie bolt..
They just wouldnt come loose, sprayed pb-blaster, tryed breaker bar, i got 450lb Milwaukee impact wrench battery powered didnt help on this side.. I stripped both bolt heads badly.. Im frustrated!!
---------- Post added at 08:54 PM ---------- Previous post was at 08:47 PM ----------
Also can i drive the car with the oem spring/old shock only on rear left, all the other sides new hr springs/struts-shocks....?
