Ahmad Babelli
- 2008 FX35 AWD
- Name
- Ahmad Babelli
Hello There guys, this is my first thread regarding a problem that i have with the Infiniti and i hope you guys can help me.
For starters, my 2008 fx35 is a gulf spec car, so it doesn't come with Intelligent cruise control (ICC), it is just a normal cruise and it has an issue.
Whenever i press the (ON) switch from my steering, the cruise light and the set light come on together on the cluster, and the set light starts blinking , and when i try to set the speed it wont engage.
It is only supposed to turn the "cruise" light in the gauge cluster and then have the "set" light on when i set the speed, but they are coming on both at the same time without me setting anything, and the "set" light keeps flashing and blinking.
I did what my mechanic told me to and switched both the clock-steering and the angle sensor, it worked for a day or two then the problem came again, can you guys suggest anything or help me please.
Best regards
Ahmad Babelli
Best regards
Ahmad Babelli
