I have not been to the forum for some time now. I decided to just drive my FX and enjoy what I have. Everytime I come back to the forum I want something new. :eeerr:
Anyrate, my horn does not work. It does not work when I press at the steering wheel. I turned the "horn beep" feature on when I lock the car. (Was not on before.) That does not work. The horn does work when I press the Panic button.
The Horn fuse (#10) checked good. As does fuse #71 The relay sounds the horn when I ground pin #1. I pulled the E9 connect in the IPDM and grounded pin 51 and the horn sounds. With the horn relay out I probe pin 1 socket. Voltage reads 3.84 VDC When I press the horn it goes to zero. With the horn relay connected with lead wires, pin one starts at 12VDC and only drops to 11.84VDC.
Do I have a grounding issue? I will not be messing with the streering wheel because I don't like the idea of acidentally setting off the air bag. But I am not sure where to look next. Before I give up and let the dealer look at it I thought I would ask here.
TIA
TIA
