Headlight Cuts out
  • Thread starter Thread starter Psiclne
  • Start date Start date
P
Psiclne
Guest
My passenger side headlight cuts in and out every so often, at first I thought The bulb went bad - I had them changed and still the same thing.
Every now and then the Passenger side will go out. If I turn off the lights and turn it back on the headlight comes back on. Any ideas what it can be?
same thing i went to with my MTEC a while back...
My passenger side did that for a bit and now it's back to normal.... It's very strange. I don't know what is causing it, but I'm pretty sure it'll go back to normal again. Turn it on and off in rapid succession. At one point my driver side wasn't coming on when i turn it on and off repeated (like 6 times). I live in riverside and maybe it's attributed to heat?
I think you jinxed me Mongo- hahaha cuz I swear it wasnt happening to me when you first PM'd me about it. It could be cuz I was in Palm Springs this weekend (110* heat) there.
that happened after i installed my 8000K's...it was the passenger light as well. i switched the bulbs around and it worked again without giving me a problem. im assuming the connection was probably loose, and after i switched the bulbs i put them in properly.
since then i have put my stock 4300's back in because the visibility from 8000K's is too little for me. if i was to go aftermarket again i would go with 6000K's.
Should I take out my 8000K?
No Will you shouldn't have to change the bulbs. Like Jeff said just have the dealer check the wiring the next time you are at the dealer. Btw, do you have
angel eyes or HID fogs or of any other headlight mod beside the bulbs?
I personally have never had this problem even after many many headlight/fog lights mods.
No other mods to the lights except the Bulbs.....it first happened when I had the HID from SCkent - so I swapped them to the Mtecs I got from you and still the same thing.
Try putting the old oem bulbs back in and see if this reoccurs. If it does then you have your answer and if it doesn't then you have your answer to. But I have the same mtec bulbs from the same vendor that is 6K and never had this issue. Did you have the headlight recall done Will? I still say have the dealer check the wiring and connectors.
