FX50 Valve / Rocker Cover Gasket Replacement
2009FX50S
Atlanta
2009 FX50S
Has anyone here replaced the valve/rocker cover gaskets on the vq50? Tried searching here but wasn't able to find anything. I have 118k miles and just started getting a bit of a burning smell when I stop after driving. I looked under the car and I have a leak coming down from the back of the head on the passenger side. I am going to take a closer look but I am hoping its just the cover gasket. Just looking for any advice. I have the service manual and pretty sure I can handle the repair.
Thanks
That's insanely cheap. On the 35 and 45 you had to change valve covers, which were about 20x as expensive.
Funny you replied today I was going to update the post and say that I have not done anything with this yet. The leak seems to have stopped and I’ve had my hands full with a new baby.
Is the gasket part of the valve cover on the 35/45 or was the cover the problem?
I believe the issue was that the valve covers had non-replaceable spark plug tube seals, to replace them you had to get new valve covers or use a hole saw to cut the old ones out and then use an older style gasket from a different engine. It looks like the VK50 gasket includes the spark plug tube seals.
I finally got around to replacing the leaking gasket on the passenger side. I disconnected a fuel line and removed a few of the breather/vacuum lines to make room. I removed the throttle body but left the coolant lines attached. The FSM called for some liquid gasket maker to be used at the corners so I picked up some Permatex Ultra Grey for that.
Link to rocker cover replacement section of FSM FSM.pdf
Tools:
10mm swivel socket
10mm offset wrench
In-lbs torque wrench
Pliers
The gaskets were just over $15 each.
13270-1CA0A - Passenger side
13270-1CA0B - Driver side
Disconnected this fuel line from the chassis and swung it out of the way
You can see here most everything that I removed. Did not remove the airbox just the intake hose. Still need to remove coil packs and bolts etc....plugs can stay in engine.
This was probably the hardest bolt to remove as there is very little clearance down there. 10mm offset wrench required.
Rocker cover removed.
New gasket
New gasket installed on cover
I know this is an old thread, but I'm getting ready to do mine. 200K miles, it's been slowly leaking/burning smell for a couple months. I'm not looking forward to it - I expect scraped knuckles, but I've got an array of offset 10mm wrenches and a super-shallow 10mm wobbly bit and a long weekend. I'm glad to see you were able to do it with the intake on. I pulled the intake 4 years ago to do the starter, and I'd rather not pull it again if possible. I did it on my FX45, which had acres of room compared to the 50.
Thanks for the pics!
Thank you for the write up, I just started getting the smell on my 2011, with 117,000 miles. I put new plugs in at 105, they were original, and switched the Valvoline restore and protect, 2,500 miles ago, just started to drive it hard. Aldo ran Yamaha Outboard Marine fuel cleaner though, 2 bottles, it. Mixes 1oz per 10 Gallons.. i cant say enough about both of those products!!!!
Update on the Valvoline restore and protect. I’m halfway through 2nd oil cycle and I’m blown away. The oil leak smell self healed! Thing is a mint. 1/0k. In town sucks 12mpg, on hwy 22-24 70-80 mph.
