My brother-in-laws 2003 FX35 (my old FX35) with 170K miles has misfire on cylinder 4 and I have diagnosed down to a leaky exhaust valve on the cylinder.
I'm trying to decide if I should just replace the cylinder heads with rebuild ones or swap in a low mileage engine, or a rebuild engine. Whats holding be back on doing a cylinder head job is the 170K miles on the engine and I'm un-familiar dealing with the timing chain. It use oil quite a bit due to worn seals/gaskets due to the high mileage it has; about a quart every 3000 miles. I have asked a couple shops to do the cylinder head job and they advise not to given the high mileage on the engine.
Swap in a low mileage engine seems to be the easiest route. I do understand the risk of inherit any problems of the replacement engine may have. And I also realize there is a separate set of problems with a rebuild engine may bring as well.
Feel free to charm in.
