threezero
- Vansterdam
A easy mod. A bit more work involve than the 1st gen but not to bad overall.
1. Take off the panel covering the license plate plates. there is 2 plastic screws on both end that should just pop out with the help of a flathead screwdriver. Once you get the screw off use something flat insert it through the cracks and pry gently. I use those flexible metal ruler and wrap the end with duct tape.
2. Taking off the panel is the hardest part, once its off unscrew the screw holding the bulb housing, it should fall out. unplug the connector.
3. The bulb should twist out either clockwise or anti clockwise, it should give no resistant don't force it out.
4. insert your new LED, I used the PIAA wedge bulbs.
5. reverse the steps and than pop the panel back in and your done.
Before:
After:
The after picture does not do it justice. The LED doesn't give out as much illumination as the OEM bulbs but its Super white with a hint of blue.
Hope this helps!
Before:
After:
Hope this helps!
