Finished the hid reverse light install last night. Took some pics during the install to share. MAIN reason i'm doing this is due to my dark tints (5% all around) at night don't help me seeing crap when backing up. Thank god for the reverse camera but that doesn't cover everything. The kit is 15w 6000k temp bulbs. Bought the kit from a ebay seller. Here are some pics of the install.
The actual kit.
Here is an example of the ballast next to a normal hid ballast.
Here is a pic of a normal hid bulb (left) compared to the reverse hid bulb (right).
To install the kit, you have to remove the hatch panel. First remove the handles using a flathead screwdriver.
Both handles removed.
There are 4 clips that are going to pop out when you pull on the hatch. 1st clip over one handle.
2nd clip over 2nd handle.
3rd clip upper right hand corner of the hatch.
4th clip upper left hand corner.
When you pull on the hatch these four clips will fly out fast so watch where they go. I used a flat head screwdriver to open the hatch a little the get my hands in there to give it a pull.
Here are the clips that came flying out.
This is what you see with the hatch removed.
Here is one of the ballast mounted in the corner of the hatch.
Here is the wiring from the ballast to the bulb. That grey plug goes to the original reverse bulb I unplugged the plug and i cut and spliced the power into the new ballast.
Here is the wiring all tied up and tucked away. The two white wires go the hid bulb.
The install for the other side is the same. Here are the bulbs lit up.
That's a pic with only 1 side lit up.
Both sides lit up.
My garage roof all lit up.
Will post more pics in a different environment and a video of them in action.
