yeah, that's about what it looked like, only the rear bumpstop was black
ok, bolts I used are made by SPC, the front most rear arm, the camber adjust, shorter bolt is pn# 72055 and the rear most arm, spring bucket, toe adjust, longer bolt is pn# 72265
both of these are confirmed 100% proper fit, perfect for this aplication and both require slotting the subframe and come with a template for doing so, and you only need one kit of each to do the job. I would recommend picking up one set of each because as you correct camber you also will affect toe so you may wind up needing both even if you think your only problem right now is camber. these bolts each affect the other, in other words the front bolt does mostly camber but also changes toe somewhat as it adjusts camber and the rear bolt is the same, mostly affects toe but also affects camber in it's adjustment so they have to be adjusted together
-2deg on the camber is not horrible but it is a bit much on a daily driver.... unless you're a very agressive driver and always beating it hard through turns and stuff... I'm a pretty agressive driver and I tuned my fx for performance and I was running around -1.8 in the rear myself so your -2 really isn't so horrible... again for an average daily though I would want ~-1.5 ideally as a max which itself is already right past the outer limits of factory spec, think the factory spec calls for no more than -1.3 on the agressive side of factory spec
also, as far as the alignment, I too use hunter equiptment... there is an adapter that is necissary to fit the sensors to larger wheels, when I did my 22's the adapter was necissary to fit the 22's... well when I went to do these 24's even with the adapter it was still not big enough to grab both edges of the 24's, I winded up having to borrow another set of these adapters from another alignment shop and use 2 adapters on each sensor, 2 sets of adapters to do this alignment with the 24's... I imagine someone who does 24's more often already has 2 sets of these adapters, I'm assuming your guy did?
