LOL i think i can deal with that then. did you get the full exhaust system? from cat back? how much is the whole system? which website did you get it from?if youre driving at a constant rate there is a small rumble. My grandman noticed it.
thanks. no gains and possible loss? that's never good.I got the full system from Lerry thats on here. You can pm him. It was about 1400ish. Ive heard intakes are just all sound, no gains and possible loss. just look up ark and his name should be up somewhere
You can PM Lerry or buy it here
http://www.arkperformance.com/mobile/Product.aspx?id=265
And btw there is no intake available for the 2nd gen.
Do you feel that you have gained power or loss?
Ok sorry about that.
alright , no hard feelings. since you have on ARK and u like it. than ima go with it. thanks for the advise again. good looking out.No worries bro, didn't mean it in a bad way. But you have two options for the exhaust, the Ark and the Invidia exhaust but I def recommend the Ark
So we have to ride with negative camber forever? that sucks
Can you buy just the extreme low rear springs? Swapping to 20" wheels with smaller tires resulted in a tiny bit of wheel gap. Front setup has a more adjustment, but rears are maxed out low and I've already pulled one lock collar. I'm about to pull the other one, but that still may not be enough. Shock still has plenty of adjustment for preload, so I'd only need the springs. And do the extreme low springs have the 14kg/mm rear rate like the regular length ones I got from you last year?
