BC Racing Coilovers special for IS members(coils/lowering kit for any make and model)
if youre driving at a constant rate there is a small rumble. My grandman noticed it.
LOL i think i can deal with that then. did you get the full exhaust system? from cat back? how much is the whole system? which website did you get it from?
---------- Post added at 06:22 PM ---------- Previous post was at 05:54 PM ----------
BTW i wanna put a new set of air intakes, but i just couldn't any. Is any brand out there make intakes for FX2gen?
I got the full system from Lerry thats on here. You can pm him. It was about 1400ish. Ive heard intakes are just all sound, no gains and possible loss. just look up ark and his name should be up somewhere
thanks. no gains and possible loss? that's never good.
---------- Post added at 06:37 PM ---------- Previous post was at 06:36 PM ----------
You can PM Lerry or buy it here
http://www.arkperformance.com/mobile/Product.aspx?id=265
And btw there is no intake available for the 2nd gen.
Thank you. ima go check it out. you guys all like the sound of it?
---------- Post added at 06:40 PM ---------- Previous post was at 06:37 PM ----------
That ARK is for 3.5L, but our cars are 3.7L Does it work?:bulgy-eyes:
This thread is getting off topic, please ask your questions via the appropriate thread Eric
BC Racing Coilovers special for IS members(coils/lowering kit for any make an...
No worries bro, didn't mean it in a bad way. But you have two options for the exhaust, the Ark and the Invidia exhaust but I def recommend the Ark
alright , no hard feelings. since you have on ARK and u like it. than ima go with it. thanks for the advise again. good looking out.
Can you buy just the extreme low rear springs? Swapping to 20" wheels with smaller tires resulted in a tiny bit of wheel gap. Front setup has a more adjustment, but rears are maxed out low and I've already pulled one lock collar. I'm about to pull the other one, but that still may not be enough. Shock still has plenty of adjustment for preload, so I'd only need the springs. And do the extreme low springs have the 14kg/mm rear rate like the regular length ones I got from you last year?
---------- Post added at 11:42 AM ---------- Previous post was at 11:40 AM ----------
Not that big of a deal. I got over 12K on rear tires before flipping them and that is at -3. Front is at -2 and I got over 20K on a set without any camber wear; tires could go another 20K easy. Keep toe in check and tire wear is not really a big deal.
So we have to ride with negative camber forever? that sucks
PM'd you.
I received your PM and replied. I want to go with your recommendation for the coilovers on the M56s. I'm ready to make it happen. Thanks again for the response.
Dee
