infinitifan25
hey guys and gals. i just wanted to share with you another way to delete your wiper with a small plug. its the similar way as the thread posted jbakers thread. He came up with a great idea to plug the hole, but i wanted something smaller more low profile. so here it is.
stuff you will need to buy: home depot or lowes
1 can of plasti-dip
1 1/8" hole plug "found in the hardware section"
and a good clear coat spray paint
and a oil,degreaser remover for paint prep
scotch bright pad for sanding the plug
clear silicone
1- sand the plug down and spray about 3 good coats of plasti-dip and two coats of clear coat. this will hold very good. it should look like this. DO THIS BEFORE REMOVING THE REAR HATCH PLASTIC AND WIPER!
2-remove the rear plastic from the hatch the same as stated. remove the wiper assembly. once everything is out and you have your hole that looks like this
3- once thats done make sure you clean around your window hole good then insert it into the hole. NOTE! the plug will feel loose. but thats okay. pry the sharp edges from the back of the plug back on all of them and squirt some silicone between the spikes and make sure you have a very good bead. you can put some between the glass and plug if you like, but this way its alot cleaner and still keeps water out. it should look like this when your done and the sharp prongs flared out.
This is the differance between the sink cove,r went over in the other threads and the hole plug. both work great and the sink hole cover is alot more easier to install. but its self prefrence on looks.
1 can of plasti-dip
clear silicone
