gchristopher9
- Boston MA
i actually won a spare on ebay that had a dent right next to clock, but it was all cut away anyways. cost me more to ship it than the auction went for. something like 7 or 8 bucks with shipping.
i cut my piece with just a dremel, and then a file to clean things up. when cutting plastic with the dremel cutting wheel it tends to melt and gunk up so the file helps to make the edges nice again. are you going be using aftermarket amps? if so it probably wouldn't be so bad as you would just have to chop into the factory head unit output and send it to the aftermarket unit. if you are using the factory bose amp then you would also have to send the audio back to the factory stuff from your head unit and it would be a lot of work. if your using the factory amp i would advise to just do what i did and wire it to the aux on the factory head unit.
