Does anyone know which wires on the head unit's wiring harness are for: switched power (ACC), constant power (BATT) & ground??? Please see my post below explaining:
FX35 - Radio Connectors
Did you try a voltmeter at the other pins? Could it be that the pins are mislabeled on the diagram that was posted? Reason I ask is because the 2005 FX35 service manual shows the plug in a different orientation that has the middle blank spot at the top. I think that diagram might be showing the pinouts on the radio side and not the harness side. Here are a couple of screenshots I took with both orientations. Hope it helps!
Service manual orientation
Rotated to match the orientation posted
Thanks Mole. I noticed in your wiring table it has pin numbers up to 21? Is that for the same one I'm using (it only has 10)?^Helpful info there. Ok I had a chance to look more at the fsm. Looks like the pinouts on the fsm are on the radio side and not the harness side so your handwritten diagram of the harness above does match.
Below are the wiring colors that I found in the fsm that might help to solve the issue. Looks like some of the wires might be mixed up.
*1: BOSE
*2: Base
Thanks Mole. I appreciate you checking anyway. How do you like the iSimple?I was able to check the wiring earlier and found that it has an iSimple unit. Unfortunately, it has an integrated plug n play harness so there was no tapping of wires. Sorry couldn't be of any help!
